Fuzeblock Mod
This mod fixes messy wiring due to added accessories.
Added accessories are generally connected directly to the battery, and each accessory needs it's own fuse protection.
Over time, the wiring for accessories becomes difficult to manage, and it takes up a lot of room. In some cases, you can't even close the battery cover.
One solution is to install an accessory 'Fuse Panel', that relocates much of the under-seat wiring to a different location.
Here is a photo of my 'BEFORE' wiring:
And here's a photo of my 'AFTER' wiring:
The difference between the photos is the installation of a fuse panel.
This Mod has the following benefits:
• Eliminates excess wiring underneath the seat / inside the battery compartment.
• Reduces the number of wiring connections to the battery posts.
• Relocates in-line fuse holders to a common fuse panel.
• During service, the technician can disconnect the battery without having to interpret the accessory wiring.
There are several aftermarket fuse panels available.
http://www.centechwire.com/marketing/spotlight.html
http://www.whitehorsegear.com/motorcycle-circuit-manager-fuse-block
http://www.cyclenutz.com/Blue-Sea-6-CircuitNegative-Bus_p_51.html
