Starting sequence
1 reading
796 views 5 replies 5 participants last post by  HyperPete
#1 · (Edited)
Hello everyone,
Was a member of the OZ Boulevards site, however this has now gone. So joined you guys.
Bought my 109 new in 2016 and have added a few extras over the years, including Freedom Short Curves, Forcewinder intakes and EJK fuel management unit. Don't ride it very often, only has 12,400 miles.
Has been going great until recently (onset winter), with original battery starting to die. Replaced it with a Yuasa and checked all fuses etc, however now the bike won't start unless the clutch lever is pulled in.
Any ideas why the bike is now doing this?
thanks
Don
#2 · (Edited)
Welcome to the forum, Cheers!... 🍻
From the Owners manual:
NOTE: This motorcycle is equipped with interlock system for the ignition circuit and the starter circuit. The engine can only be started if: • The transmission is in neutral and the clutch is disengaged, or • The transmission is in gear, the side stand is fully up and the clutch is disengaged.
#4 ·
Thanks vili and Zoom for the welcome. What I don't understand is that until recently I have not had to pull in the clutch to start bike. Provided the bike was in neutral, key on press starter and bike fired first go every time. It could be this clutch switch may be on it's way out?
#5 ·
The clutch switch closes the ground circuit to the starter relay.
Without the clutch lever pulled, the starter relay would (should) not function.
The only portion of the ignition interlock that functions differently if you are in neutral compared to being in gear is the side-stand relay.
#6 ·
I thought I had the same issue one spring. I think I was just confusing my Yamaha with my Suzuki.
I seem to recall being told that you need to pull in the clutch to start all Suzukis.
