1 - 5 of 5 Posts
just got yana shiki 2 in bones. i understand the nuts & bolts of taking them off. i need to know if you use stock bushings & bearings? do not have stock bones off yet. also went with me880 front & rear 160 / 260 can't wait to install everything.thanks 4 any replies:confused:
I got the same ones. Bearings from the stock do not fit. Trust me I tried. Just grease the holes nice and good. Thousands of miles on mine and no problems.
Lowering Bones
I have the same 2" bones and no the stock bushings do not fit. Have not had an issue with mine and they have been on there for over 2 years now. Expect about a 2 1/2" drop with the Yana bones.
Same here, just grease the bolts that goes through them and the openings in them good and bolt them on. I've had mine on for most of 3 years and have checked them and there's not enough wear to tell they have loosened at all. They don't move that much.
Put grease on any outside faces that contact another part of the suspension or part of the bike, such as the lower ends where they sit inside the box on the frame too.
1 - 5 of 5 Posts
