$14,790 (Raven) Available from February 2010
$14,990 (Deep Blue) Available from September 2009; CA model February 2010
Engine
Type 113-cubic-inch (1854cc) air-cooled V-twin OHV, 4 valves/cylinder
Bore x Stroke 100.0 x 118.0mm
Compression Ratio 9.48:1
Fuel Delivery Twin-Bore electronic fuel injection; throttle position sensor
Ignition TCI: Transistor Controlled Ignition
Transmission 5-speed,multiplate wet clutch
Final Drive Belt
Chassis
Frame Double cradle
Suspension/Front Telescopic fork; 5.1-in travel
Suspension/Rear Swingarm; 3.5-in travel
Brakes/Front Dual hydraulic disc, 298mm
Brakes/Rear Hydraulic disc, 310mm
Tires/Front 120/70-21
Tires/Rear 210/40R-18
Wheels 5-spoke cast
Dimensions
Length 101.2 in
Width 36.4 in
Height 45.9 in
Seat Height 27.4 in
Wheelbase 70.9 in
Fuel Capacity 4.1 gal
Fuel Economy** 42 mpg
Wet Weight*** 730 lb
Other
Warranty 1 Year (Limited Factory Warranty)
