1 - 7 of 7 Posts
i have a good battery load tested ,but it will not start ,all the lights go ,but i press the start button and theres a click under the seat and then everything turns off i rest the key wait two minutes and the same thing click under the seat by the battery i need help
start with the easy things first:
red kill switch off?
kickstand down and still in gear?
make sure battery cables are tight too
Bad starter relay?
What are your wrenching skills like?
This could end up being an involved checklist to work through to identify the problem.
I think you need to check your earth / ground to the frame . By pass it by connecting a jump lead from negative on battery direct to frame , engine bar etc. If starter turns over then that's your problem.
Try it anyway.:super:Gez
had same problem, dealer said it was ground cable from battery, where it bolts on to engine block, remove and check for paint, remove if any, and replace cable , end of problem for me.
yup as stated above; sounds like you might have a loose cable somewhere.
you might also want to but a muti meter on the battery as you crank and see how far down your volts drop.
hit it with a hammer! if it still wont start then its definately electrical!!:joke:
1 - 7 of 7 Posts
