You should do what you like as long as you can till the "man" takes it away and they all end up sounding like vespas. I like noise too, lets em know I just passed thier cage.:bigthumbsup:should I run my V&H big shots with or without baffles? I just took them off and really like the way it sounds. :dontknow:
If you just remove the fiberglass packing it doesn't change the flow, so no changes needed. If you remove the baffles the flow will change, so a remapping might be needed for best performance.If you remove the baffles or the fiber glass, do you need to retune the PCIII?
How was the sound without the packing? I like the BigShot's deeper note, but wanted it louder. I am afraid removing the packing or the baffles will make it louder but not the same deeper note...just took a ride with the packing removed and I didn't like it. taking the baffles out and putting on the Vinnieb map.
