1 - 9 of 9 Posts
   I have been riding for 30 years and have never winterized a bike.  Mostly because the bike never sat more than a couple of months at a time.   But I broke my foot two months ago and and will most likely not ride for at least a couple more months.  :dontknow:
   Should I go ahead and winterize at this point?  Will 4 months of sitting cause damage?   I keep my 109 is a temp controlled area if that makes any difference.
Redman,
Since your bike is in cilmate controlled area here is what I would do. I would give it a good washing and waxing. I would change the oil with a regular 10w-40 conventional oil, fill the gas tank and add Stabil. Put a motorcycle trickle battery charger on it and lastly if you have a motorcycle lift like the one that Sears sells. I would put it onthe lift to get the tires off the ground. Oh... don't forget to put a warm blanket on, to keep her comfy until you ride her again.
C-One
WHOA....
remember to run the bike till fully warm AFTER adding the stabil or only the tank will be protected. Elsewhere it could still gum up.
If possible I would also run it till fully warm every 3 weeks or so. This step can only help when it comes time to ride again.
The fully warmed up is important because if you only warm it a little... and other parts are not warm it can cause condensation in places you wish there were none.
Sledzep
Or, you could send her my way. I'll keep juices flowing! :joke: :bigthumbsup: Nothing wrong with having 3 bikes in the garage to choose from. :joke:
and add Stabil
i recommend this as well. i put this stuff in my jeep before i went to iraq for a year. when i came back, i hooked the battery cable back up, and it started right up.
Texas Winterize List:
Gloves
Jacket
I guess there's some advantage for taking 2 months of blistering heat.. I never lived outside of the Houston area and only been in the freezing cold days at a time. I forget that up North the winters get really cold for a Long time...
Gloves
Jacket
Texas list:
Gloves
Jacket
Heated Corbin seat
1 - 9 of 9 Posts
