1 - 1 of 1 Posts
i drilled out the three inner walls in each stock pipe and drilled eight half inch holes in each pipe also. my question is if i cut the back plate were the eight holes are and pull the baffle out to will that be gutting to much out of the pipe or should i just leave well enough alone ?? i like the look of the pipes with the back plate cut out . will it run the same and sound the same if anyone has some suggestions please let me know.
1 - 1 of 1 Posts
