1 - 20 of 23 Posts
J R said:
Well we are at 68 inches now 72 might look right :dontknow: :bigthumbsup: See if you can draw one to scale and try different looks when ya get the time :bigthumbsup: I mentioned a long time ago I thought that extending the swingarm would be a cool look :bigthumbsup: also might as well widen it :evil:
Actually I am the most concerned about the driveshaft. I was a little worried about extending the one on the VTX1300 but that engine is about 65HP. How safe will an extended driveshaft be on a 109? Not too sure myself.
Hey , thats your Knueter valve body......gotta have somewhere to pour your blinker fluid....... :joke:
That is a wicked VTX, I likeee.....
J R makes some good points , wonder how it would look with it a few inches longer and everything lowered accordingly ......then the rake.....have fun.
J R said:
I like that bike :bigthumbsup: You still have it or is that the one ya sold ? It looks great Hal :evil: :bigthumbsup: :doorag:
A Trooper up in New York bought it and hauled it home. He says he is the big dog now in his town.
J R said:
Well I once did it in the 80,s to a v-max and used part of a C.V joint shaft from a car that was about the length I needed and then did the ends ect and it held up till i went to a chain conversion. Im sure you could do somthing similar.Just make a whole new shaft a little bigger in diameter :dontknow: If they can make um hold up in these kids front wheel drive cars Im sure ya could come up with somthing that will hold :doorag:
The VTX driveshaft had a Rockwell hardness # of something like 85. A local shaft builder wanted $1,000 to build a new one that met that hardness.
And here is my baby when it went away:
Thanks. I may not have a way to get them home. I will let you know.
By the way if the M109 is: 68 inches
Here are the numbers from the VTX1300 when it was done:
Axle to axle wheelbase is now 79 inches
A stock 1300C is 64.45
A stock 1800C is 67.6
So we are now 14.55 inches longer than the stock 1300C and 11.4 inches longer than the 1800C.
hahaha i spent 10 minutes trying to figure out what the pic up there was ^^^. thought it was some kind of contest lol. but but but the picture was kinda fuzzy and low light lol.
I'm sure you can get a machine shop to make one and then have it hardened. It shouldn't be $1,000. Take it to a mchinist instead of a mechanic/auto machinist. The Guy you took it to probably knows he can get $$$$ for it.
The costly problem was the tooling required to cut the metric splines. And he was only doing one. Rob from BCC finally just cut my shaft and added a piece. But every time I rode that bike I kept thinking that some day the shaft will be coming out of the swingarm housing and into my leg.
Think that is about one of the best looking custom VTX's I've seen...nothing over the top and you can never go wrong with plain ol' black paint.
This has to be one of the best VS800 Choppers I've seen. He made a new gear box to extend the swingarm...and I foget the details but may have used the swing arm from a VS1400. He also, as you can see, mounted a 240 rear tire.
More info on various links: link1, link2.
This is the same bike I ride (look at my sig). You'll notice the differences in the gear box/shaft drive areas.
If you cut ours in half and added a piece I don't think I would worry too much. You would need to undercut both joints, fill with groove weld and grind to remove any extra buildup (perhaps even turn it back down on a lathe). The most difficult part would be keeping the thing true after welding. I don't believe hardness would be an issue as the heat affected zone of the weld should carry a greater hardness value.
The biggest concern for me would be balance. The longer the driveshaft (especially with non-homogeneous material) the more possibility of vibration from an out-of-balance shaft.
Just my $.02
-Jeff
1 - 20 of 23 Posts
