Look just like my Kewl Metal Air Ride. :dontknow::dontknow:http://platinumairsuspension.com/2009/08/21/suzuki-m109-bleed-feed-suspension-kit/
here is another manufacturer.
lil bit more expensive but seems to be good quality
:agree:My money is still with Arnott..
I passed along his complaint to my son who runs their CNC machine at their Cape Canaveral plant.I still also think Arnott makes the best system, but if you ask Giddy109 he might say different, click here. I think that there are only 2 companies that make an air ride for our bike, Arnott and Kewl Metal. I think Arnott changed some of there parts so they could be made for less money. Good luck with which ever way you go. :bigthumbsup:
that kit is basily that same as the kewl metal set up and you will have pogo issues with it.http://platinumairsuspension.com/2009/08/21/suzuki-m109-bleed-feed-suspension-kit/
I had the KM on for two years and never had pogo issues with it. Have you ever seen this posted by someone that had one? The only problem I had with it was the same as you have with any air ride, and that is if you lower it all the way down or close to it you can't ride them that way as they bottom out.that kit is basily that same as the kewl metal set up and you will have pogo issues with it.
i ride arnott. so far so good. had one issue but they fixed it.
their "bleed feed" kit stops the pogo effect...the standard kit is what your thinking about.that kit is basily that same as the kewl metal set up and you will have pogo issues with it.
pynikal, the firmness won't make a difference whether it rubs or not. It controls the internal dampening in the shock and makes it either stiffer or firmer, but it has nothing to do with how far down it goes. That's providing you have the stock bones on it which won't let it bottom out even fully lowered.just wondering what setting do you guys set your shock on??
im on the 2nd hardest setting so i can slam it with no rubbing.:doorag:
