I'm due to replace my clutch hub, part# 21410-48G00. I've long since done the bluey fix. Worked great, but the vibrations slowly came back. I'm going to start over and get a new basket.
Question for those that have replaced their basket before. Did you also replace the "Gear Assembley part#21100-48G01" and the "Disc Pressure part#21462-48G00".
Or did you just replace the basket. Just wondering what other parts are maybe a good idea to replace at the same time. My clutch is fine, so I might put in a new wave washer and seat for good measure.
Click the picture below to expand.
#1 SPACER 21151-48G00
#2 GEAR ASSY 21100-48G01
#3 HUB 21410-48G00
#4 SPRING 21413-48G00
#5 PLATE #1 21413-48G00
#6 PLATE #2 21441-48G10
#7 PLATE #3 21441-48G20
#8 PLATE #4 21441-48G30
#9 PLATE DRIVEN #1 21451-48G00
#10 PLATE DRIVEN #2 21451-48G10
#11 DISC PRESSURE 21462-48G00
#12 SEAT 21471-48G00
#13 WASHER 21472-48G00
#14 BOLT 21482-41G00
#15 NUT 09159-24010
#16 WASHER 09160-25056
#17 WASHER 09160-25056
#18-1 2006-07 WASHER 09164-24006
#18-2 2008-09 WASHER 09164-20008
#19 BEARING 09263-32020
#20 ROD 23110-24F00
#21 ROD L 23111-48G00
#22 PIECE PUSH 23121-41G00
#23 BALL 23122-02FR0
#3 HUB 21410-48G00
#15 NUT 09159-24010
#20 ROD 23110-24F00
