1 - 8 of 8 Posts
Im am so stuck, did the clutch tonight and started the throttel cables and that darn screw is imposible to get out. What is the secret, HELP!
I know what you mean..I used my dremel to cut into the screw then used a flat end screw driver to take it out ...
:agree: Same here. After I got that sucker out, I replaced it with a chrome allen head....problem solved!
In the future, if you see this coming you can put a little dab of valve lapping compound on the tip of the screwdriver and it will get a good bite on the screw and allow you to free it up. Works like a charm!:bigthumbsup:
1 - 8 of 8 Posts
