1 - 7 of 7 Posts
Hey guys I have a general question here I have noticed latley that around the 3200 -3400 rpm range I have a slight vibration in every gear and at various speeds but only in gear the vibration isnt there with the clutch lever pulled in its only under load that i feel it as I have said it is only there for around 200 rpms but is noticeable anyone else have anything similar with theirs I am definately thinking drive shaft
Thanks guys have read through all the posts by this i am going to ignore it but must say i dont like it but might learn to live with it :p
I believe that Taz told me after he put the JSD mod on his bike that the 3-4k vibration issue became much less pronounced.. anyone else have any experience with that also?
i have had the same problem since new and it is worse with someone on the back...this tells me tailshaft angles are wrong t.the angle changes when someone sits on the back and that changes the vibration maybe the rear needs lifting up a bit
1 - 7 of 7 Posts
