If the valve clerance is a little off, can this cause a studder/misfire between 2000 and 2800 rpm while cruising? I have 16000 miles on a 2006 m109 with air cleaner mod, wide open stock exhaust, timeing advance and cobra 2000 fuel processor. I also changed the battery but it will not go away.
One other thing I did was to do the brown wire mod for the fi light because I removed the exhaust control valve actuator. Can there be a problem that will not set off the fi light because I did this mod?:-\
