1 - 6 of 6 Posts
How in the heck do you get wiring unclipped from ejectors. I'm installing cobra fuel manager and quick connects on ejectors will not come loose! Afraid to get too rough with them.
Just like all the other connectors there is a cli[p to push before they come apart. If you look at the connectors from the fuel management system they should be the same. BTW they are INJECTORS.. not ejectors
Sorry,
I work in soybean processing plant where you have ejectors that pull mercury vacuum on distillation vessels.
Gottem mixed up
Push it all the way on to take the load off the clip and push the clip and pop/pry it off.
I put everything back together last night and went riding today. I may have the shop install it. Wish I had good photos of an install. Cobra instructions leave alot to be desired.
1 - 6 of 6 Posts
