I saw a picture of turn signals mounted on the the fender, but I can't seem to find them. Anyone got a good link? What are you guys doing to for the front? Just looking to sleak it up a bit. Thanks.
I think this is what your looking for!!I saw a picture of turn signals mounted on the the fender, but I can't seem to find them. Anyone got a good link? What are you guys doing to for the front? Just looking to sleak it up a bit. Thanks.
I have a question I ordered the Raw Design Suzuki M-109R LED Rear Turn Signal but it didnt come with directions. does anyone know how to install this?I think this is what your looking for!!
http://www.directlineparts.com/product.asp?pid=6808&str=290
I have Flatz for the front of my 9 I like them alot!!
http://www.directlineparts.com/product.asp?pid=9068&str=290
Click and download !!!!!!!!I have a question I ordered the Raw Design Suzuki M-109R LED Rear Turn Signal but it didnt come with directions. does anyone know how to install this?
Thanks for the help T, it did me wonders, it was very easy to do after reading the instructions.Click and download !!!!!!!!
i bought from them,installed by this instruction !!
http://www.datafilehost.com/download-c5db8483.html
M109-R "Stealth" Rear Blinker Installation
1-Remove seat and body panel
2-Remove 4, 10mm bolts that hold the stock plastic turn signal in place
3-Cut off the turn signal / plate holder, flush. A utility knife works well.
4-Reinstall newly trimmed piece with the 10mm bolts and place the back body panel on.
5-Take the RAW Turn Signal bracket, place under back body panel and line up with edge of fender. The ends of the RAW bracket should touch or be close to the seat supports. Mark the 3 small bracket holes.
6-Take the body panel back off and drill the marked holes with a 3/16" drill bit.
7-Install the RAW signal bracket
8-Run the new wires along the stock harness holder. Cut off the connectors from your old signal wires and connect to new signal wires. Your new signals only need 1 ground (black) wire. You can take the other from the stock lights and tape it off. It doesn't matter which one.
9-Reinstall the back body panels and adjust RAW signal as desired. Test blinkers.
10-Reinstall your seat and ride safe.
If you have any questions, please do not hesitate to call our tech. support line 8AM - 4PM , Eastern Standard Time, Mon.
Some have to cut them off or drill them out. Make sure you get a bit that fits the screws tightly for a start, and make sure you press in firmly while you turn. And I've taken them off with a hand impact wrench.Hey how you took the front signals off, the screws are super tight
