Just got via mail fender eliminator /turn signals from ebay(customizedbikeparts.com)and the connections are not the same.2 wires on the lights(black/yellow) vs the 3 wire connection with the stock harness, not the same plug either, what to do
Yes because LED's will only work one wayI just installed a set of signals with similar wires (black/yellow). If I remember correctly, the yellow is your hot wire. The best way to check this is to take a nine volt battery and hold the wires to the connections. LED's require very little power, and the nine volt will light them up nicely. Welcome to the site. :bigthumbsup:
