Need some pointers on how to change my transmission fluid. I"m clueless and don't even know where to start.
Change the oil and as a bonus it also changes the trans fluid. No further work needed but changing the oil and filter.i have to change the oil to so what all should i do
:agree::agree::agree::agree::agree::agree:take it to a dealer:dontknow:
Only if you have the manual tranny. If you've got an automatic transmission the fluids must be changed separately!you have 2 drain plugs on the pan take them both out drain the oil and then just put back in . The engine oil is runs the trans also. hope this helps.:bigthumbsup:
:doh::a20::a20:Only if you have the manual tranny. If you've got an automatic transmission the fluids must be changed separately!
