ditch said:
So could you give us a little more info as to what the parts are from, what it cost, and how hard it was to put on? I think I would like to try it but would be nice to make it as easy as possible with the most amount of info on it. Thanks, looks great :bigthumbsup:
For difficulty level, I'll put it like this, I tap on a keyboard for a living (system analyst) and can pick out the correct end of a screw driver 3 outta 4 times. It took some patients to figure out which screw needed to come out to take the backend down to subframe, but I got there. As for parts; from what I saw for license plate holders, almost any sportbike kind will do since you are going to have to do some cutting and drilling anyway. It came with bent tabs which made mounting the turn signals a no brainer. Of course, a couple of small 'L' bracket coming off the top holes on the license plate would do the same job. As other have stated, LaMonster included, you will have to take a cutoff wheel to that ugly piece of plastic in the back. Just take your time and look carefully where to cut and drill. I also mounted a 5-LED clear light strip for plate illumination at night. (Used strong 2-sided foam tape for that)
License plate bracket - $50.00
Turn signals - $20.00
Clear LED's for plate illumination - $25.00
Could probably have done it cheaper, but WTF, it was all right there when I was at the shop.
