My Boss Hossrxhealer said:Now which one do you enjoy the most? They both are sweet bikes. The more I ride the M109R the bigger my smile gets!!!!!
You like?OMEGA said:God if I could only get my hands on a shorty 2 into 1 like that for the 109![]()
I was thinking the same thing. I like the black primary pipes and the chrome end. Very nice. That would look tough on my Black 109ROMEGA said:It's perfect, did you have it made?
I built a soft tail suspension for that bike and cut and rake the frame. I have Kewlmetal bleed feed air ride on it also. It is much lower than stock but when I pump it up it still corners pretty good. I plan on lowering the 109 some and I should have my 300 tire for it tomorrow so I can take a look at how that's going to fit.toneout said:Do you have air suspension on the VTX? It looks much lower in the picture in the garage. I would like to get my M109R much lower. MUCH LOWER! The only problem is that I already drag my heel while cornering. It would only be worse lowered. But it would look much tougher.
That is the air box for one of the throttle bodies. The crankcase breather is just ran to the one side.toneout said:I thought so. I didn't however realize you cut and then raked the frame. That is way out of my budget. (So is air ride actually) I would like to see some lowering links to drop the bike about 1 or 2 inches and springs for the forks.
I also would like to get the intake. Just an air tube and filter. Something to let it breathe better. Of course there would have to be something on the left side to to get rid of the breather. I cannot believe I have all that crap on there for a crankcase breather.
This might be a little over the top but this is a duel intake with 52mm on a VTX. 8)sledzep01 said:So there is actually an intake on both sides right? I think I read that someplace so...
Would an improved intake be freely from both sides? or just great from one?
I think I would like the idea of an agressive looking/working intake on both sides. It would something else that makes the 109 standout
SledZep
Wow, that is crazy looking. LOLLamonster said:If you really was some air you can do this.Â
