1 - 12 of 12 Posts
What exactly does the dealer do on the 600-mile service? Is this just an expensive oil change?
If they do it correctly there is a whole checklist of stuff including the rear end fluid, alot of re torquing etc. my tech spent 4 hours doing mine.
Now Bob's is an example of incorrectly... all dealerships are different . I am lucky to have a small shop that runs a racing team and has a primo technician.
Prior to my 600 mile service I covered all exposed bolt heads with the plastic chrome caps. Not one of those caps was disturbed during the service which indicates to me that the Stealer never torqued a bolt, other than the drain plugs if that.
On every cycle I've owned, my first purchase after the bike is the Service Manuel. I ordered that from my dealer four weeks ago and I'm still waiting to receive it. When I get that in hand, my first chore will be to go over the entire bike with my torque wrench after removing all the bolt caps.
As I perform all my own work to include tire changes and balancing, and my dealer has a $58.50 shop rate, I figure my savings add up rather quickly.
I just received a coupon from my dealer service manager for a free filter and oil on my next visit......unfortunately they want $129.00 service charge for that visit. Grant you that's a $40.00 savings over the 600 mile service. I just purchased a Dunnie 250/40-R18 for $120.97.....I think I'll buy another with the $129.00 savings :) :) :) :) :) :)
talk about not trusting the stealers.....i went to adjust the handlebar ..bring it up some and the top bolts on the clamps were tight and when i got to the bottom ones ...they were completely loose to were i loseen then up with my fingers...hows that for trusting stealer mechanics.
When I got my bike home, the two bolts that lock the front axle in place were loose. Noticed this after I took it for a spin. Then of course, after 400 miles on the clock, the overfilled crankcase made itself known. Anyone know a a reputable dealer in Orange County, CA?
Shop spent 2 hours putting on Cobra Pipes, spent 1 hour going through Oil Change Proceedure. Shop Tech Showed the protocol to me, there was so many start for 15 min, turn off for 3 min, check oil, restart for 4 min, turn off for 6 min, drain Oil......It made me dizzy, Tech told me he had a 2 hour class just to change the oil.. He spent soo much time changing oil, I never saw him do anything else.
They are also supposed to check throttle sync at the 600 mile service. That is probably the only thing a regular person couldn't do on their own, as you do need the proper dual vacuum gauge.
Wanted, the 600 mile throttle synch is for the Euro model M109R's not ours. check the service manual. :bigthumbsup:
1 - 12 of 12 Posts
