1 - 16 of 16 Posts
Wire diagram for installing tail light with integrated turn signals.This set-up will allow your turn signals to flash at normal rate.The tail light I used was purchased from D2MOTO.
For a nice clean set-up, I cut the plug from the OEM turn signals so that after its all wired up I can just plug into the harness on the bike. that way if I have to take the tail end apart, all i have to do is un-plug everything. Very simple :bigthumbsup:....Click here for other instructions and scroll to the bottom
Administrator
You can also use a digital flasher which won't heat up or burn out.
I thought that the ones from D2moto were holding up well. Has anyone else had leds go out yet on theirs?
Yes I have. It lasted about a week tops.
just got mine, everything is working fine but the brake light is not working:dontknow:.
all the fuse are good. just the plug that should work brake and runing lights, like stock right? did i miss something here, or anyone had this problem?
thanks for the any help.
Dragon
I had the very same problem. I took the taillight apart, and found that there was a wire that was pierced through a solder joint creating a short. Put it back together, and still no brake light. The guy did refund my money thru Paypal. So I don't think its a wiring issue. Vinny
Re tail light.
Mate the same thing happened to me ,swap the red and green wires in the new tail light plug and it works great.Micko.
Micko.....this was a WAY OLD thread and was dealing with the first or second generation lights....not the ones currently available
1 - 16 of 16 Posts
