1 - 10 of 10 Posts
Yes, it was part of a mounting kit to hold the side mount tag in place.
Ok, I have not seen that kit before. I went with the cycle house kit by DLP. It mounts into the top plug on the hub. Easy install and keeps the plate a little closer in. That set up you have uses an expansion plug that goes inside that axle if I am not mistaken. Did the expansion plug not lock in.
Here's what I have
http://www.directlineparts.com/product.asp?pid=6250&str=290
that is how shane mounts his side plates that is a threaded rod that goes throug the rear axle it should have a pin in the other side exhaust side to hold it from turning and a lock nut!!! pm me if you need more help
Here's what I have
That is exactly what is wrong! The expansion plug is locked in and I can't get it loose. You have any idea how to get it out?:dontknow:
1 - 10 of 10 Posts
