1 - 1 of 1 Posts
Supporting Vendor
Introducing a line of EVO electric tank bags by SW-Motech, a German manufacturer of durable and reliable motorcycle accessories and parts. The company has been operating successfully since 1999 offering a range of bike crash protection and luggage products. If you find it difficult to pack all the things you need on your trip in your saddlebags or top box, or just want convenient storage for your frequently used items and valuables, consider getting an SW-Motech EVO electric tank bag.
Using a special EVO 2.0 electric quick-disconnect tank ring, you can keep the devices in your bag charged thanks to a seamless connection with your bike’s electrical system. The circuit is active only when the bag is connected with the ring. The tank bags are available in a range of shapes and sizes, so you can be sure to find an option that will fit your needs best. Note that you need to get a vehicle-specific EVO Tank Ring to make the attachment.
SW-Motech® - EVO 2.0 GS Electric Tank Bag
Specifications:
EVO GS tank bag:
• Material: 1680D Ballistic Nylon / 1680D Ballistic Nylon
• Color: Black / grey
• Size: 31,0 x 25,0 x 41,0 cm / 12.2 x 9.8 x 16.1 in
• Weight: 2,1 kg / 4.6 lb
• Total Volume: 16,0-22,0 l
EVO 2.0 Electric top ring:
• Color: Black / red
• Weight: 0,7 kg / 1.5 lb
Features:
• The EVO 2.0 electric top ring is screwed to the EVO tank bag instead of the standard top ring
• The EVO 2.0 electric kit can be used for any EVO tank ring
• The circuit is closed by snapping the top ring on the tank ring; the circuit is disconnected when unlocking the top ring
• Operating current maximum 5 amps
• Direct connection to the vehicle battery
• Fuse in the cable harness (5 A)
• Vibration-resistant mounted, gold-plated spring contacts
• Waterproof plug connection between cable harness and power contact
EVO GS tank bag:
• Inner storage with mesh compartment
• Zipper to expand the volume
• 3 outer pockets
• 2 cable feed-throughs
• Durable carrying handle and shoulder strap
• Connectors for GPS mount, map holder, smartphone or tablet drybag
• The patented EVO tank ring provides a secure hold for EVO tank bags and allows you to lock and remove them with a single movement
• Pull strap for releasing the QUICK-LOCK mechanism is secured with a snap fastener
• Can be used with a cable lock or anti-theft protection
• Individual mounting of the upper ring for best fit
• Reflective details for better visibility
• Weather protection with the supplied rain cover
• High form stability due to EVA plastic base and padding
• Made from durable, highly UV-resistant 1680D ballistic nylon with water-resistant interior coating
SW-Motech® - EVO 2.0 Trial Electric Tank Bag
Specifications:
EVO Trial Electric Tank Bag:
• Size: 33,0 x 19,0 x 38,0 cm / 13.0 x 7.5 x 15.0 in
• Weight: 1,9 kg / 4.2 lb
• Total Volume: 15,0-22,0 l
Features:
• EVO Trial tank bag:
• Integrated map holder that also supports touch function on digital devices
• 2 outer pockets
• Fits GPS mount, map holder, smartphone or tablet dry bag
SW-Motech® - Street Rack Adapter For EVO Tank Bag
Features:
• Material: Fiberglass-reinforced polyamide
• Color: Black
• Weight: 0,2 kg / 0.3 lb
• For securing EVO tank bags on the adapter plate for STREET-RACK
• QUICK-LOCK function makes simple snapping on of the following tank bag models possible: EVO Micro, EVO Daypack, EVO Sport and if need be EVO Engage
• Easy assembly: EVO tank ring is screwed onto the adapter plate
Click on the image to enter the product page at MOTORCYCLEiD.com for more information.
To browse the full catalog of SW-Motech products, click the "Shop Now" button below:
Give our sales team a call at 888.903.4344 (Toll-Free) or 1.732.867.9995 (International) and we'll match any competitor's price.​
1 - 1 of 1 Posts
