Posting for posterity.
Background: I only recently bought my 9 and have not really had a chance to ride her for any length of time that would draw the tank below half way before I would fill it.
Two days ago I went on a nice, long ride. I would guess my tank was about 2/3 full. About 45 minutes into the ride I started to get a stumble/hiccup. I would apply a touch more throttle, or gun it, and the engine would cut out for a split second. It got worse and worse over the next 30 minutes - but never consistent where it was doing it non-stop or anything close to that.
Note: I did add a little less than half a bottle of techron fuel cleaner to the tank of gas in question. And I always use premium gas.
My most likely causes:
Yesterday I took the gas cap apart and thoroughly cleaned everything. It was pretty gunked up, so hopefully it was just not venting like it should. I also ordered a new fuel strainer for the pump pickup.
I'll report back in a few days if the problem persists or if the new gas and cleaned gas cap vent solved the issue. To be continued...
- bad gas, or water or some other contaminant that only got into the fuel system when the tank was low on fuel.
- blocked fuel strainer (filter).
- Gas tank is not venting.
