1 - 4 of 4 Posts
Hey i had read a post about if you take the two sets of wires that run to your exhaust off the exhaust runs louder. Is that true? if so, does this do any harm to the bike? just want to get all the info before i were to try something new...
With everything else in place you wouldn't notice the difference. All that does is disable the SET valve, which makes it stay full open. If you were to debaffle the exhaust you might tell the difference.
Keep in mine you can't just unhook the SET wires or it gives you a check engine light. You either have to put a cam on the actuator or pull a wire on the ECU.
well i have mine debaffled... any how to on how to pull the wire from the ECU?
1 - 4 of 4 Posts
