1 - 19 of 19 Posts
ok i cant seem to find any how to or pics of the stebel mounted into the headlight bucket well i did find one but the photos have been delete so that is not helping me out. i have a good idea on how and where i just thought if anyone had some pics that would be nice
Seasoned Member
Note that I did not secure the horn to the black nacelle backing plate. Just use zip-ties to loosely secure the horn to the nacelle stay. Take care not to block the 3 nacelle mounting points. Don't worry about the horn not being secured tightly... it will get "squished" in place when you put the nacelle back on. Mine has been going strong for 3 1/2 years and I blow that sucker numerous times every time I ride. :bigthumbsup:
Front:
Left side:
Right side:
Front:
Left side:
Right side:
no pics they aremt showing up
I see them even in your quote? Do you have a mac? :joke:
I was at work damn gov computers blocked it out and I didn't even think about it. Lol
It fits behind the radiator quite nicelly if you every have that area apart.
?????????well i dont see how this plug in play harness is going to work it has the wires for the stock horn and the stebel heat shrunk together so i dont understand how they expect me to wire it???:dontknow::dontknow::dontknow:
I sent a couple of replied Pms about this. :dontknow:
When I mounted mine I zip-tied the :edit: out of it...good and TIGHT, but it's really not necessary because like Seapup said, when you squeeze the nacel back on the horn will get squished up tight inside it. It actually took me several tries removing the zip ties and making slight adjustments before I was able to get the nacel back on. Once mounted it won't move unless you hit a large truck head-on, in that case you may want to get a new one anyway. ;)
see the wiring harness i have
man if you have the tach relocated its gonna be tight!
Tight ? how about impossible or close enough that it will frustrate the :edit: out of you ....
I would'nt put the stebel there if you ever plan on relocating your tach or installing HID lighting as you will need the space for the transformer / ballast .
that is about all the room that i have in there. and that nacelle is a major PITA to put back on.......:verymad:
I have the tach reloacated and the HID kit in there . The nacelle goes back on however you are right , it can be a pain ....
The stebel mounted under the seat is just as loud as mounted anywhere else on the bike ....
some guy out there with no life and a DB meeter might prove me wrong however my ears can't tell the difference.
I split the horn, pump/cylinder is under my seat with a hose run to he bucket firing the horn part of the Stebel. Works beautifully.
I had to come up with something due to tack relocation, HID lights in there too.
I love it when somebody posts a " genius way " like this
Thanks , always nice to know.:bigthumbsup:
1 - 19 of 19 Posts
