I've read a lot of negative reviews on the Stebel Nautilus, and am interested in any alternatives that others have tried. Any suggestions?
I am not sure where you read those. There are a TON of people that have them on there 9 and LOVE them. So far mine has not glitched once.I've read a lot of negative reviews on the Stebel Nautilus, and am interested in any alternatives that others have tried. Any suggestions?
Remove the SET and pull the pin in the ECU. now you have room! Or there should be room on the other side behind the side cover as well.I know most everyone on this site loves their nautilus, it was on a general internet search that I found negative reviews, primarily involving the durability/longevity of the horn. Also, I have an R2 (no bucket headlight) and an aftermarket exhaust (with the cam under the side cover) so where would I mount it? Any advice?
Same here, I've had mine on for at least 2 years now and it still works fine. I don't recall any of them failing, unless someone mounted them wrong. They have to be near vertical.
:agree:with the above comments. I have had one that has performed flawlessly for years. You might check with rynosback if you decide to go that way, he was making some harness for a while that would sure make things eaiser on your install.Usually the failing point on the Stebel horn is not the horn itself but the cheap relay that comes with it. Just toss the cheap relay in the trash can and pick up a replacement relay at your local auto parts store and you will have a loud horn that lasts for years!
:agree: i have never heard anything negative about the stebel air horn. mine has worked flawlessly for the pasy year since installing it.I am not sure where you read those. There are a TON of people that have them on there 9 and LOVE them. So far mine has not glitched once.
Plus I do not think that you will find an electric horn as loud as the Stebel.
:agree::agree: The thing about the internet is you will always find bad reviews on things. People rarely take the time to post up a positive experience. I have had mine on for almost 3 years and it is going strong. I feel it is such a great mod, I have it in the Bang for the Buck mod thread. Between this and an HID, you can increase you safety 100 fold for under $200.Remove the SET and pull the pin in the ECU. now you have room! Or there should be room on the other side behind the side cover as well.
