1 - 16 of 16 Posts
When I'm riding I hear a continous squeaking sound from my front brakes. If I hit the front brake, it will stop for a few minutes then pick back up. Does this mean the front brake is going out? I'm at about 3700 miles. Also that fron tire has been off several times (tire, front forks repair) would that have cause a problem? Any comments will be helpful. Thanks
If i remove mine I always like to lightly sand the surface of the pad and rotor it will re-mate better that way . If they were new I would file the leading edge down to help with the noise .
Take your calipers off. Get some coarse sand paper, and scuff the hell out of your pads. Then spay with brake kleen. Then, do the same on the rotors the same way. Try that. If that doesn't work, you may need to get some brake quiet, and apply to the back of the pads. If that doesn't work............ New pads I guess.:dontknow:
1 - 16 of 16 Posts
