1 - 8 of 8 Posts
I posted about a week ago about my speedometer sticking and got a couple of replies, but still having some issues. I pulled the sensor cleaned it off, did not fix the problem. I pulled speedometer face and needle, put a couple drops of wd-40 in the hole seemed to get better but still sticks a little and seem to hesitate on deceleration.(Trying to stay away from dealership) HELP :dontknow:
I would have to think you have a bad sensor under that side cover then. If the needle is free and clear. The needle moves from the electric pulse from the sensor. I am not sure but that makes sense to me LOL
Sounds to me like it is multimeter time and find out what's up since the normal fixes did not cure it.
if my memory serves me you didn't say "stick" in your other thread. Sticking and erratic behavior are 2 different things. Have you gone through the resetting procedure?
Not sure what you mean, I've had the speedometer apart(face off and needle pulled ) cycled the key to set needle back to correct position after putting wd-40 in it???
manual
In the owners manual,as pointed out to me by some helpfull 109er on here, there is a reset procedure,might be worth a try.....
to reset speedo,
1 press the adj button and turn on in ignition
2 press and hold the adj button for 3-5 sec
3 release the adj button and press the adj button twice within 1 sec
its what the book says
Have not done that, will try that asap. Thanks fro the info, I appreciate the help!!!
I hope the adding of a water dispersant to your speedo didn't hurt it. WD-40 is not a good lubricant. I would try maybe a dry graphite or a very small amount of air first then the dry graphite i would think the WD-40 would make it drag from the weight. This is just my experiance. Just be careful putting anything in a speedo. JMO:doorag:
1 - 8 of 8 Posts
