1 - 20 of 20 Posts
I just bought my 07 two weeks ago. When I ride a short distance and turn off the bike and then go to restart a few minutes later, the engine cranks slow like the battery is low. I have tested the battery and it is 100%.
If I keep holding the starter button it will crank after a couple of revolutions but then the engine idles high for a few seconds.
Any idea what this could be? Starter maybe?
Sounds like you need a battery.
It does not sound like you are holding a full charge.
· Radio Active Member
If your battery has been load tested and it is with in specs then more then likely you are learning the characteristics of this bike. This is a comon thing. The bike can be tough cranking when warm/hot. Like when you stop for gas/smoke/drink and then get back on with in 10 minutes. Those big pistons can be tough to move.
I bought an 06 new and don't remember that ever happening. Just afraid its gonna strand me somewhere. I am going to check all of the grounds today and then see if I can get it to act up with an amp gauge on it to check starter draw.
Mine was doing the same thing. The battery has lost some of it CCA ability, even with a full charge. I pulled the battery and found it was some off brand battery...
So I replaced it last week with a new Odyssey PC535. Spins the motor and fires within about a half a rotation.
Note: My clock was getting reset when it would stumble trying to crank the engine. Too much power being drained from the battery to spin the motor, fire the plugs, and run the electronics all at once..
As for the starter being hot. Mine would usually start easier when it was hot and stumble with it was cold or lukewarm.
Discussion Starter · #10 · (Edited)
That is the same battery I have! Where did you get the Odyssey? And did it fit without modifying?
Got mine from Gman Industries. It came modified to fit the M109R but it was too snug once I installed it and almost could not get it out. So I trimmed the side fins just enough to make it snug but still removable without using a claw puller.. :D
I had once in the beginning problem with the ground wire, but my bike did not want to strat up at all.
Now it is starting perfectly.
1 - 20 of 20 Posts
