1 - 2 of 2 Posts
Hey Itguy,
Mounting the bracket in that upper left bolt hole worked out just as you said. It has been 6 days and no movement what so ever. And getting the bolt from fasteners.com was easy as them overnighting it in one day . also clearlens .com will be getting the intergrated tail lights in about a week. so cleaning up that rear to show all that 240 is easy now.............Holla Gman
GMAN M109 said:
Hey Itguy,
That hole is for the shock bolt on another Zuki bike...the 109 and Suzuki C90 use the same rear! I used the same hole with a 16mm 1.5 pitch oil drain plug. I drilled the plug on a lathe and taped it to accommodate a 3/8 inch stainless button allen bolt. The design for my mount uses the axle head as a positive stop. There is virtually no movement....you could put a jack under the mount and raise the bike!
http://image1.frappr.com/pix1/i/20060730/9/0/8/908fbc5cce5bf51843c334da0aa383ad0_large.jpg[/img]
1 - 2 of 2 Posts
