1 - 7 of 7 Posts
where is it and how do you electronicly unhook it? may want to try it for the heck of it. i have read there is 2 plugs going to it, but can't find it. just want to check out the difference.
its right after the two pipes meet into 1 just unhook the spring this helps to open it up and takes 5 minutes it will always be in the open position without the spring. i also took the baffles out and did a kn mod with the cobra FI2000r and the resister mod and the bike is running really strong. i've had it dyno'd at 114.5hp and 112.9torque. it seems to keep getting stronger. still working on scanning the dyno chart. if you do a search there is a sound clip of it.
Hey Wally... when you're checking through some of the older posts, note the date they were made...
The one you responded to happened to be roughly 2 years ago... :D
1 - 7 of 7 Posts
