1 - 3 of 3 Posts
Sorry to carry one but Ive also taken out the SET valve, I just used two small "u" clamps and over lapped the two control cables then clamped them together so when the valve goes through its cycle when firing up trike the clamps come to a stop at each cable outer sleeve the same as the valve would in its position in the exhaust. No muking about with FI wiring, its been working for a year or so no problems, only needs a couple of inches of cable over lapped and not much movement left to right as the vale does not go through too many degrees either, I just tucked it all out of sight and tie wrapped it up out the way.
1 - 3 of 3 Posts
