Good knowledge. I guess a servo isn't really necessary. Just didn't want to have my lights flung off, if it's all the same I'll just go the cheapest route. I'll Much appreciated .
If you have an older bike, and this trick works on 2010 and older, but if you can unplug the top connector from the ECM, cut the black wire with a tan stripe, and I heat shrinked it, that is all the cost there is, and you cut a few pounds out of the bike as well. No FI light. there is a service bulletin for the Dealers to pull the pin to eliminate FI light for the servo and O2 sensor removal.
