1 - 6 of 6 Posts
Does anyone know the thread size of the 4 mounting bolts for the secomdary driv unit??? I took mine off the bike to realign the diff and popped it off when i was torquing it down:edit::edit:
So if I get the size I will know what size to use when I re-tap it.
Anyhelp is appreciatted.
Roger
All 4 bolts are the same, so just take one of the others with you to get a tap. I think they are 10 x 1.5 or 10 x 2.0, but I'm not positive.
Check it against the die in the tap and die set...just sayin.
They are 8mm x 1.25mm , METRIC not sure of the lengtht:bigthumbsup::bigthumbsup::bigthumbsup:
Right on!! Thanks guys!!
1 - 6 of 6 Posts
