1 - 3 of 3 Posts
Just picked up my new BLACK 109. My handlebars seen a bit low to the tank. Could I rotate the bar up for a better riding position? And not disturb any cables? I dont think I need the risers. I like the length, just need hight...
Yes you can, but the controls (or the bars) have tiny nipples? on them and dents in the controls to locate them.
Many have said they took a dremel to them and all was fine.
Beware that if your cables were cable tied to the bars instead of just "together" then you will have to remove them from the bars to have room to rotate the bars.
Sledzep
Actually, I raised mine to where the bar end is level with the middle of the bar without rotating my controls and they work fine. I did take the ties for the cables off the bars and then re-tie them when I moved my tach to make everything look better, though.
1 - 3 of 3 Posts
