how hard was the install, also did you use a pcIII or some kind of map? what do you suggest??:dontknow:
Depends on which RB exhaust you're going with but the install is pretty straight forward as long as you have some mechanical skill and tools. I went with the Velocity Pros and a bully fuel controller for fuel mgmt. If you are just going with pipes and have a stock air filter set up, you do not need fuel mgmt.how hard was the install, also did you use a pcIII or some kind of map? what do you suggest??:dontknow:
