Not sure, don't know how sticky their compound is. If it's not sticky or tacky then I would think you'd be able to. Shoot 'em an email an ask.http://www.rhinotire.com/
Cool idea. I wonder if you can still use dynabeads though?? Didn't read far enough on the website to figure it out.
No you should not be able to use beads with this tire. Plus the tire may take A LOT of weight because of that stuff lining the tire. The reason is that it will make that tire much heavier. I think DLP sells stuff that you inject into the tire and it does the same thing plus keeps it balanced. But it takes a while for it to work its way around when you have it in storage for a while.http://www.rhinotire.com/
