1 - 4 of 4 Posts
I have misplaced my owners manual and the clock reset when I unplugged the dash connector changing the plugs the other day. can someone give me the sequence of button pushing to set it? I know how to do the trip meters but never Have reset the clock. thanks. ::)
If I recall ... you press and hold both buttons simultaneously until the clock digits begin to flash, then press the right button to select the hr or min digit, then press the left button to increment the selected digit, etc.
Though, I could have the left/right button functions backwards ...
thanks again, you were right. hold down both and hour digit flashes, use adj button the right to change hour. hit select again and minute digit flashes, again use adj button to change. when done hit select again and time is displayed normally. :bigthumbsup:
1 - 4 of 4 Posts
