1 - 2 of 2 Posts
Are the bolts on this bike standard stuff? I was trying to find a few longer bolts, took out my tap and die set to use the gauge and it says they are 1.0 thread count x 4 mm when I go to find a longer one, everywhere Ive looked has a standard stock that is 1.0 x 6mm if you drop to 4mm the thread count also drops. Where can I find these bolts?
I could be doing something wrong to, I hacked off my shifter peg to put a silver 12 gauge shotgun shell peg on and that used a 5/16 diameter 24 threads per inch bolt, I wanted a longer one to put a spike on the backside of that and the same thing happened everyone stocks 5/16 bolts in 18 threads per inch to go to 24 TPI the bolt then is too narrow? Whats up?
As my bud and I worked on my07 M109 we swore that we ran into metric and SAE nut and/or bolts etc, etc. Maybe they are just not precise enough? Got me!
1 - 2 of 2 Posts
