1 - 20 of 58 Posts
Was wondering if the factory paint could be removed from wheels with a standard aluminum strip chemical? Are these wheels powder coated? I have removed paint and clear coats from auto wheels in the past and the result is a machined looks that really stands out.
You try it first. Worst comes to worst, just get your brother to paint them. They'll already be off. I still think painted wheels would look tough especially with the white walls. :eek:
Sorry, just in case anyone was wondering, he doesn't really have whitewalls on his M109R. :D
Are they actually painted a color? or are they just clear coated to help them clean up?
Sorry for the silly questions but untill Tuesday I am still a "gonnabe" upgraded from "wannabe"
They look like a clearcoated metal to me.
SledZep
The bike that cobra did has polished wheels. I am painting the bike now and will be polishing the wheels while waiting for the clear to set up. Should have it done next weekend. Came up with a side mount plate and signals to clean up the rear end. No more plate hanging down.
vtxoak said:
The bike that cobra did has polished wheels. I am paint the bike now and will be polishing the wheels while waiting for the clear to set up. Should have it done next weekend. Came up with a side mount plate and signals to clean up the rear end. No more plate hanging down.
Post some pic's when you get a chance.
I like painted wheels better than polished in my opinion. My 2003 Buell Firebolt had polished wheels and they were a pain to keep clean! With painted wheels, I can wax them and the dirt washes right of with soap and water.
ps- Did anyone notice that the wheels are made by Enkei ? Enkei makes real nice wheels for car and are not cheap! Way to go Suzuki!
-Chad
Not only did I notice that the wheels were made by enkei but I also noticed that they have "BMF" pressed on them. Just like Samuel L. Jackson's wallet in Pulp Fiction. They're the ones that have "Bad (I know work safe site)" on them. :evil:
Painted verses Polished.....having had a 02 VTX with bare aluminum rims I can vividly recall the long hours and large quantities of Mothers Polish, not to mention the sore fingers, which was the norm for maintaining those wheels.
One of the first impressions I had about the M109 was the "CLEAN" appearance of the painted or powder coated wheels. Not sure of the finish, but I do like the ability to simply wet a cloth with Windex and give the wheels a quick wipe.....presto, the wheels are clean. Having a 8.5 inch wide rear wheel is like having a waste basket for brake dust to collect, after every ride there is a accumulation of dust......less work cleaning wheels is more time in the saddle.
I would gamble and say the wheels are powdercoated. All of the Suzuki sportbioke wheels are powdercoated as well. Paint is to soft, especially when it comes to changing tires. I'm thinking of doing something like a polished lip on the rim edges and doing a gloss black center rim....not sure yet. I will need to spend some time photoshopping it.
I tryed applying some aluminum paint stripper to the hub in a place where it could not be easily seen to see what it would look like. It appeared to of had almost no effect. I then tried a small spot on the outer lip. It did remove a small amount coating. The base aluminum color is very close to the fatory paint color, just a bit darker. I am toying with stripping and polishing the lip and leaving the hub machined.
I have now borrowed a friends used Hyabusa wheel to try a stronger chemical stripper and if that doesnt work I have an appointment with a sandblaster. One way or the other the paint is coming off. The finish on the Hyabusa wheel is black but underneath is a really nice machined surface. I will update.
metu said:
Was wondering if the factory paint could be removed from wheels with a standard aluminum strip chemical? Are these wheels powder coated? I have removed paint and clear coats from auto wheels in the past and the result is a machined looks that really stands out. Â
Chrome!!!
http://www.classiccomponents.com/pricing.htm
$500 per set including freight back to you... Some folks I know from other boards have used them and they are very happy!
I personally think that chrome is the way to go. Will match perfectly with the rest of the chrome engine parts.
PAINT????? What kinda mullet-head would paint his rims? :confused: Don't tell me you want your 109'er to look like a Yamaha Warrior. If you must go, you must go chrome!!!!! I've seen chromed wheels on all kinds of sportbikes and they go well with the look. The 109'er, to me, looks more like a crotch rocket than a dressed out cruiser, with chrome to boot. Chrome dem bad boys!!!!!!!! :bigthumbsup:
www.hellrisercustoms.com/oychoppa
1 - 20 of 58 Posts
