1 - 9 of 9 Posts
I Had my Kury rear LED small bullets on the reflector mount with a formed bracket. I moved them to the rear with a small flat bracket. It made out of .09 thk stainless (I painted them flat black so they wouldn't be seen). All that is needed is to drill a couple of holes behind the struts. I think that they look much better here and can be seen better, even though they don't stick out much. What do you all think.
z4woo,I mounted mine(stock lights) in the same hole that the reflectors were in. It moves them up the rail a little farther. Both ways look good! :bigthumbsup:
I originally mounted them where the reflector mount was, and made some formed offset brackets, I figured that this would be easier because most people don't have access to a brake (bending machine), it just a flat piece of sheetmetal, which can be shaped with a hacksaw or grinder.
The chrome driveshaft cover is actually a piece for the C90 that a local dealer had in stock.
They look nice closer to the rear like that :doorag: I have mine mounted to the reflector brackets, too, to keep them out of the way when I use saddle bags. I may end up doing like you did, though. They are definitely more visible there :bigthumbsup:
I forgot to mention that I used button head allen screws because there isn't much room behind the struts. I originally used a regular hex bolt, but the struts didn't tighten up because the hex head was hitting the strut.
z4woo said:
Where did you get that plate cover? :bigthumbsup: I could use that on my GSXR
1 - 9 of 9 Posts
