Theses your answer I guess! =) I not ridden many on the back only like twice!Kuryakyn does not make an adapter for the passenger for the M109R, a bit more expensive but you can go with the Cobra floorboards, those are what I have on the rear of my bike.
Are these boards easy to fitKuryakyn does not make an adapter for the passenger for the M109R, a bit more expensive but you can go with the Cobra floorboards, those are what I have on the rear of my bike.
I can post some pics later, these were on the bike when I bought it but I believe the cobras are a direct bolt on replacement.Are these boards easy to fit
And any pictures
Kuryakyn makes rear adapter for the 9.Kuryakyn does not make an adapter for the passenger for the M109R, a bit more expensive but you can go with the Cobra floorboards, those are what I have on the rear of my bike.
No, the 4351 needs the splined adapters, the 8822 does work on the M109R but they are tapered, not splined. For the 8822 tapered adapters to work you would need to find floorboards that use the tapered adapters.will this adaptor fit kuryakyn floorboards 4351
Thank youNo, the 4351 needs the splined adapters, the 8822 does work on the M109R but they are tapered, not splined. For the 8822 tapered adapters to work you would need to find floorboards that use the tapered adapters.will this adaptor fit kuryakyn floorboards 4351
