1 - 6 of 6 Posts
Need a little help... when removing the rear fender, are the two screws on the underside that need to come for the fender removal the two phillips heads that would require use of a short screw driver above the tire?
i had mine vibrate loose so i would recommend some loc-tite when you reinstall!
You really don't need a short screw driver, you can use a long one just put it on the side of the tire and it works just fine.
:agree: I use a long one and it helps to align them better going back in. They are more a screw than a bolt so it's easy to get them started crooked.
1 - 6 of 6 Posts
