I am having the second gear popping into neutral problem. Don't have the money to fix right now. Can I change to a different weight oill and help this problem temporarily
hate to say it Bro but I`m thinking thats not going to help you can sure give it a try but I would hold my breath!! Sorry!! Good Luck thoughI am having the second gear popping into neutral problem. Don't have the money to fix right now. Can I change to a different weight oill and help this problem temporarily
Now it would be interesting to know what causes this problem... Could it be that clank we hear when we dont preload into 2nd that causes taer and wear...?No...we had a member here that rode his with a bad 2nd gear for some time...mostly he started in 1st then upshifted into second then third consecutively. If it is second gear the engine has to be removed and the cylinders broke down and the cases split. Then gears that are damaged including new shift forks and shafts will need to be upgraded. Sorry to hear and good luck.
That's part of it, the other part is just shifting it too hard.Now it would be interesting to know what causes this problem... Could it be that clank we hear when we dont preload into 2nd that causes taer and wear...?
