1 - 2 of 2 Posts
Where did you mount and tap the load equalizer into your wire harness if you even put it on?
The instructions say to tap it into the harness before the fuse panel.  Just wanted to see where anyone who installed one put theirs.  If not, are you just letting them blink faster?
Thanks!
I always tap into the FENDER side of the harness...about an inch or so behind the connector.
I solder a wire to each signal wire and one to the ground wire then put female spade or bullet connectors on them. Then i put the male connectors on the 3 wires of the Load Equalizer.
It's always worked very well for me.
billh
1 - 2 of 2 Posts
