K627
1. Are you sure it's an 18 inch, not a 17? I couldn't find a 130-90-18 listed.
2. When was this tire made? The date code has the week/year made somewhere on it. You don't want to use a tire over 5 years old even if it's "new". Rubber gets harder (more slippery) as it ages, and is more prone to blow out.
3. If you do consider using this tire, check the load rating to make sure it can handle the weight of the 109, passenger, and gear.
4. Is it a tubeless tire, radial, speed rating?
5. The more I think about it............don't use this tire.
