1 - 5 of 5 Posts
I just printed out the how to from Dickschiff and have a question. Am I correct in saying the pull cable is closer to the driver and the push is closer to the headlight? And pull is the top on the motor or the bottom?
We, need a little help here!:dontknow: Key word was WE...
The pull cable is the one with the adjuster in it. If you look at the bottom of the housing, it's the closest to the lever, or to the front of the controls. I think on the motor end it's the top cable, but I'm not 100% sure. But if you hook it up right on the control end you can figure out which it is on the motor end.
The adjuster is the chrome piece on the stock cable that's right under the clutch reservoir.
1 - 5 of 5 Posts
