1 - 1 of 1 Posts
I bought a LED integrated smoke tail light and got it all hooked up and for some reason the right side stays a solid yellow and does not flash and stays on when the turn signals are not even on. The left side works fine and is red and brightens when the brakes are applied and also the turn signal flashes and turns on and off. I also installed the flasher relay and the left turn signal flashes normal. I just have the problem with the right side staying yellow all the time. The solid yellow goes away on the right side when I unplug the right turn signal wiring. Does anyone have any ideas or is it just a crap tail light? :confused::confused::confused:
1 - 1 of 1 Posts
